MikeT
- Jan 17, 2001
- 4,095
- 11
I just got a 1996 KX60 and the bike runs awesome but the clutch is doing something I have not felt before in a bike. When I put it in first gear and let the clutch out slowly the clutch seems to grab a little then slip a little then grab again... If I let it out quickly you only feel the grab/slip a little then when it is all the way out it engages fully and will pull 195 lb me away with no problem.
What is causing this? The bike was apparantly sitting for two years unused. I need to check the tranny oil because the site glass is completely full (I don't see any air above it) I am also assuming the site glass is accurate on this bike. I do plan on draining it and just measuring out the correct amount but what is my clutch problem??
