Hey guys,
i just bought an 02 cr125.. good condition.. the guy told me that the clutch cable was streched... reason why he said this is because, when you pull the clutch in and go to put it in 1st is stalls as if the clutch plates are not being released.. I put a new cable on and adjusted it.. and the same thing happend... no matter how you set the adjustment on the cable unless it;s to the extreme.. the plates on the clutch don't release, and it's as if the clutch was not pulled in.. i took to clutch cover off, to fine gray oil.. and everything in tach.. along with the friction plates and pressure plates all looking A ok!!... i'm stumped.. any help would be great... oh yea.... i checked the shaft and pin.. nothing is broken..
Thanks!!
Thanks!!
