93 suzuki RM125, installed new hinson clutch basket, new clutch gear housing, new clutch kit with springs, can not adjust cable, if i leave the slack like the manual says, it will leap forward and die when i put it into gear, and is hard to put back into neutral when running, if i take all the slack out where it will not do this, it will still will not work correctly, any ideas, installed everything according to manual....need to go ride................thanks..
