So, reading through my service manual, i see that my clutch should move 90 degrees when pulling the cable. mine appears to move about 40-50. i have tried adjusting the nuts on the lever and down by the clutch itself. also that spring down on the the actuator is not really doing anything, i guess this is from the lack of full travel.
is there something i can adjust to get the full 90 degrees on the clutch? is the clutch going bad?
i do not notice much, but this is my first bike and i have only been riding it for 4 months. i have noticed that if it is in gear with the engine off, if you pull the clutch and try and roll the bike, the cylinder moves.
any advice?
any advice?
