KanickKDX
- May 30, 2005
- 5
- 0
I searched first. You guys are all too expereinced for me to understand everything i found. All the posts assume the reader knows a little. In my case that is not a good assumption. I intend to learn by doing.
Here's the deal.
My 92' KDX is really hard to start in gear and it pulls with the clutch pulled idling in first gear. This is worse than before.
I adjusted the clutch at the top 2 adjustments and even with all the freeplay gone in the lever I couldn't get it to improve. Is the clutch finished?
The bike is the one I am using to teach my nephew and others and they use the clutch really hard. Brutal in fact. The bike is awesome and stands up to the abuse. I love it.
I changed the oil last fall and it has been ridden one weeekend by the youngsters learning to use a clutch for the first time.
I am clueless but brave. i can call experienced friends to supervise me if I dig in and run into problems.
Are there visual inspections i should do? Are there routine things I have not done? How will I know when the cluch is finished?
Can I replace it myself or do I need help the first time?
Keep it simple. I will do my homework if you can tell me where to start.
Thanks from a newbie.
Here's the deal.
