lovetoridezx6r
- Jun 7, 2006
- 43
- 0
I've taken apart the clutch and found notches on the basket and hub. My mechanic told me to replace the hub, and shave down the notches on the basket. I did these things, put the bike back together. When first started it seemed perfect... smooth shift into first when it originally lurched and died. Then the next couple times shifting out of nuetral into first, it started again the same thing. Clutch drag. My mechanic also said that my steel and friction plates were all ok. I'm lost, everything else looked fine. I can't get my release arm out, but my pressure plate moved out 1/8 of an inch away from the friction plate which is supposedly what it's suppose to be at. Thanks for any help. I'm just stumped.
