What should be the compression psi range for an 98 CR125.
I have 115psi kicking it hard 10 times with gas open.
I bought the bike used early this year. Is it time for a rebuild?
Update! I tore the topend apart, the cylinder mearsured 2.1251-2.1255. But the piston didn't fair very well. 2.1220 at the skirt and 2.114 right below the ring. :eek:
How much should the piston taper for top to bottom, about .0020?
The bike ran fairly well but lacked top end.
Getting a Pro-X piston set with .012 base gasket kit. (stock is .020)
Sounds like I should be in the 160-185 psi range.
