Compression Tests on Suzuki RM125 1992
$PICOLE
Just wondering if anyone has compression tested a similar bike (or any 125cc for that matter). I have not been able to find any test info. specific to a 125. Mine is coming up at 110PSI. The bike is stock. My buddies CR125, is coming up at 118PSI.
So I am wondering what is good and what is not? Does 110PSI mean it is time to re-build the top-end??
83MX80
347
yes it does. when my KDX didnt want to start without being pulled or rolling it downhill i thought it was the topend and the guy at my local yamaha shop said topend also. but i did a compression test on it and there was 153PSI.. but he said it should be between 120-125 PSI. but 110 seems a little low. i would rip the topend down and inspect it.
rm_racer
501
Im pretty suprised that it still runs at 110 PSI. My RM125 quit running at about 120-125. Its should be atleast 140 - 200+, but over around 200 or so you will probably need race gas and what not.
phranticness
134
what kind of tester are you useing, the accuracy of cheap testers is questionable, a schrader valve in the head of the adapter, and the correct length of threads is pretty vital.
