D-doubledash
6
why is there coolant mixing with my oil? do i have to split the case to fix the problem? i have a 89 kdx 200 e1. i need help fast. and how do you feel about a hybrid? my front end came from a kx 250.
sr5bidder
1,463
no need to split cases just remove the clutch cover and remove the gear from the back of the pump.. pull the pump then the seal and push a new seal in
It's the seal behind the water pump?
The water pump should be on the right side of the engine in front of the clutch. It has a hose or two going into it.
julien_d
1,788
remove the clutch cover. The clutch cover is on the RIGHT side of the engine. You'll need to remove the INNER cover not the small round outer cover. Once you get that off you will plainly see what needs to be done.
julien_d
1,788
how you gonna replace the water pump oil seal/bearing with no money anyway??? It's quite likely the side cover gasket will be re-usable if you are careful taking the clutch cover off, but you'd still have to buy the seal and bearing for the water pump.
