MXHowes
Re: '89 KDX 200
I am getting radiator fluid in my oil. I would first suppect the water pump seal but is there some other place it could be comming from?
Thanks, Jim
wornknobby
625
well most likely it would be and water pump seal. i have seen a common problem with those seals on these bikes. another place it could be coming from would be if your head gasket was leaking :ohmy: :ohmy:
cweingartz
241
If the head gasket leaks on a two-stroke, the coolant would go to the exhaust, not the oil. You will notice white "smoke" from the tail pipe when the head gasket leaks. Probably the waterpump seal.
