I have a question about my cooling system. I recently had my whole engine re-done and got a new cylinder put on my 1993 KDX 250. I got it back together adn broke it in. It seems to be having a problem wiht the coolant comin gout of the over flow hose. The odd thing is everytime i check the level of the coolant(after each ride) it seems to be at the perfect level when cold. I filled the radiator up when it was 10 degrees out and it is now around 50. no idea if that makes a difference. It seems to spew out the most when i stop and shut the engine off. The last time that the coolant come out of the over flow hose the head gasket was bad and was causeing presure to build in the cooling system, but i was losing quite a bit of coolant when that was the case. Just trying to figure out if it is the head gasket or something else....????:whiner:
