So I bought a 97 Cr 125 about a month ago.. It was a basket case, paid $475 has a motor in pieces and almost everything else missing a silencer, but it had a pro circuit pipe.
So I went through put the motor back together the kid I bought it from said it had a new piston/ring in it(from the looks it did) and I finished everything tons of little odds and ends(replaced, 1 radiator, water pump, bearing etc.etc.etc.) Finally get it all together yesterday and go to try and fire it up and nothing.. man this thing has less compression than my 125cc 4stroke pitbike and 1000x less than my yz250..... Can't find my compression tester so I go to my buddies and it was averaging between 30-40psi... OUCH.... SO looks like the piston is pretty sloppy I'm about positive it will need to be sleeved or bored and I'm looking at my options.. I'm only about $800 into the bike... I'm really considering boring it to a 144cc I believe it was 0r a 149cc..
I'm wondering is it really worth the money?Will it be a noticable difference? Will I be able to keep up with my 250? I'm 6' 200lbs.... And also of course where would you guys recomend having the work done I want to get it started right away... Are there any dowsides to a big bore kit also??
Dan
Dan
