hoydamm
42
I have a 2000 cr 125 and the throttle cable seems to be to small. I have made sure all the thighteners r fully closed so it has as much room as possible and it is still to short. Can I get a longer cable for it some where or is there another way to lenthen it?
rc331
101
If this is the stock cable that came with the bike I don't think it is too short. Are you sure that it is routed properly? If you check your manual there is a diagram that shows how the cable should be routed. If you don't have a manual take a look at some one else's cr to see how it should be routed. ;)
Hope this helps!
yzeater
1,995
I once thought my clutch cable was too short. Every time I turned to a significant degree, the lever would come in, and the bike would be into neutral. A good ole routing check should be in order
marcusgunby
6,450
Make sure it runs on the correct side of the front number plate bolt-this will make it seem too short if its on the wrong side-you want a direct route as possible to the carb with out and sharp bends.
