HajiWasAPunk
807
I was told that our CR85 could be losing fluid due to the cap being bad and not holding pressure. The same guy said that if you look at the radiator while the bike is running with the cap off and see the fluid circulating you'll know the pump is fine (I did this and it looked fine). However, after replacing the radiator cap, it still is losing fluid and needs to be topped off every couple of mottos. Any idea what the problem is?
