Hello everyone.
Currently I am running both a 1999 mod and stock CR125 moto in kart racing. My mod moto is fine and operates perfectly with all the works however the stock unit I have which I just rebuilt (top, bottom, reeds, removed and plugged power valves/we do not use in karts and jetted perfectly from my earlier notes) does not rev past 11.5 k or so. It just stops pulling. After plug readings, to want more fuel (looks leaner on the top-end), but I am nearing ranges that are settings for my mod moto, which makes close to 40 hp compared to stock.
It definitely loses peak power which I know before modifying the current mod motor I have never had a problem bringing the rev's up to 12.5k with a 12.8k over rev, with the exact same parts. Any help or recommendations would be greatly appreciated as I have tried timing changes, carb changes, but used same pipe and configurations from a working setup.
Could it really be a stator or ignition system. I changed box from a vertex to stock and its the same thing.
Very perplexing…. :bang: :bang: :bang:
Thanks everyone for any advice or recommendation as I spent all Saturday testing at my home track with no resolution.
