sbeauchamp
- Aug 14, 2010
- 7
- 0
Hopefully this is a dumb (easy) question... My 2000 CR125 is having problems shifting up from second. If I reach down with my hand and push the shifter back down (just before it hits neutral) I can then shift up to 3rd, 4th, etc...
In other words it will shift up through gears easy with a little help, but without pushing the shift lever back down, I cannot shift up. It will shift back down no problem.
If I had to guess... there must be a spring that pulls the shift lever back down, ready to shift up gears again. Is this correct? Before I started taking things apart, I thought I'd reach out for some help.
thanks!
thanks!
