Is there a problem using an '03 CDI on an '01 engine? The coils and plug caps are the same on both bikes, but I suspect the spark curve's and maybe rev limits (??) are different between the two years. Any ideas or know problems? Thanks.
Good question...........I've heard the map in the 2003 hurts the upper rpms. I want to try a 2002 CDI. But if the 2001 works that might be another alternative.
