griffbones
- Sep 12, 2006
- 329
- 1
I never said that it could not be jetting! But just as one can not jet a bike over the internet, nor can one simply state that his problem is jetting and completely rule out electrical problems either! I simply brought up the suggestion because I have had the exact same symptoms on a correctly jetted bike and it did turn out to be a bad pulse coil on the stator assembly. It also sounds to me like he has already hit most of the basics, and if he has ridden the bike for past six years with out ever fouling plugs, it is very doubtful that the jetting would now be off so far that it will only run 30 minutes with out fouling plugs. I do understand that perfect jetting can change, even between motos, but I also think a person has to keep an open mind to other possiblities. I truely hope he can fix this by simply replacing the float valve or by making a simple change in his jetting, but until you personaly fix the bike yourself, don't slam suggestions made by others. After all some of us just may happen to know as much about bikes as you think you know!mox69 said:Well about 8 people have suggested jetting to him so far.
Like others have said just because the bike ran good before is not an indicator that the jetting is perfect.
Unless he is riding his bike in a temperature / humidity controlled biodome and distilling his own gas the jetting is a good place to start!
But hey, if he wants to buy stators off f33bay and swap them feel free. Maybe he'll get lucky :)
