82camaropace500r
- Feb 18, 2005
- 1
- 0
Hi, ihave an 85 cr500r motor i have in an 85 atc 250r frame, that im having a lot of problems with. igntion problems really. I used the entire system off an 85 500r except the plug coil, which was off an 85 atc 250r. i rode it some and later blew out the stator, burnt a wire off. so i found a flywheel for the 85 ignition system. so i put that on and left the plug coil from the 85 atc 250r on it. i rode it around, and run a lot better. i went to start it the next day and it jsut backfired and now the stator dont work on that one now(85 system). Would it be blowing the stators because im using the 85 250r plug coil? im clueless bout this one. any help is appreciated! ~Jeremy
