Hi All,
Just wondering if anyone can help me, I have replaced the crank shaft seals and put in a new dirt digger clutch in my son's CR85.
After finishing putting it all back to gether late the other night, I thought I will kick it over to see how it was but was unable to start it due to noise. It will kick over but it is still in gear and won’t start, the motor spins freely. It stays in gear and have found that I can't select neutral with the gear lever. I adjusted the clutch cable up and can feel the tension on the lever, but won't release the gear when pulled in. Before I pull the clutch case off again to inspect it as all the fluids are now full has anyone had the same sort of issues or any ideas of a fix.
I’m new to your forum and have found some interesting stuff on here.
Thanks for your help in advance.
