reepicheep
- Apr 3, 2009
- 670
- 2
I'm getting ready to split the cases to replace my splineless transmission output shaft. While in there, I will be replacing all seals and gaskets.
What about the crank bearings? Thats another $50 I would rather not spend, and I don't know if it signs me up for a bunch more work beyond splitting the cases... I think those bearings are pressed in somehow (manual is at home, I'll have to check)...
This is a 95 that looks to have had a lot of hard riding. That being said, I checked the crank and rod from the top with the piston removed, and it is well within spec, with no discernible play, slop, or crunchy noises. The rod and wrist pin bearing look perfect as well, in spite of the fact that the piston skirt was cracked.
Historical indications (by excavation) are also that the previous owners ran this thing insanely rich and with a high oil mix ratio. So I don't think those bearings were ever wanting for lubrication...
I'm hoping that an old bearing in spec is just as good as a new bearing. I'm also not going to be going nuts riding this bike all the time... with 4 kids and a demanding job (both of which come first) I am lucky to get 10-20 days riding in a year... so I won't actually be putting a lot of hours on it.
So is it foolish to not unconditionally replace the crank bearings if you split the bottom end? And does replacing them require special presses and processes? Or are they wear items that just drop into the cases...
Thanks all!
Thanks all!
