Hi all
I'm sure that I am sucking in air somewhere causing the bike to run lean. Jetting OK.
Does anyone have a method of checking of air leaks, I don't want to strip the whole motor before knowing for sure.
A thought I had was to make a fitting that bolted in the spark plug hole and preasurise that crankcase with the compressor and then check with soapy water and look for bubbles, but what preasure would I go up to? I don;t want to cause more damage than there allready is.
Thanks to all
Mark
Thanks to all
Mark
