chris_psmith
18
KDX220SR with a stripped output shaft and an ominous squeak that sounds like its coming from the flywheel side crank bearing.
I am about to split the case to change the shaft and crank bearings and was after any tips to help, specifically:
1. How hard is the case to split without special tool or should i make a tool to do it?
2. Pressing new crank bearings in - difficult or not?
3. Re-assy of two cases - best way to keep it all aligned and any way around the tool to keep the crank halves aligned?
4. Pressing the two cases back together - big c-clamps or what?
Any help gratefully received, ta!
Would have posted a photo of the beatiful stripped shaft but the site thinks the link is spam.
robmcd
4
I just split and rebuit my case - I have yeasr of experience with cars, but I am new to bikes. My workshop here is basic, but I used the press at my place of work
1) I split the case with out special tools, I was going to make the special tool, but I could not find a long enough bolt or threded rod to do it (metric is pretty rare in Albama)
2) My bearing was easy to re-move and install - but like I sadi we have a basic hand press at work which I used.
3) While it was stripped I cleaned it all up, hence some of the alignment was lost - it took a couple of attempts to get it aligned, the main problem was the gear changing tumbler - but it works good now.
4) I simply lined it up and pushed it back together, a little brut force and it went together. Jsut try and keep it all striaght - the same gap all the way around and it should be fine.
Good luck
canyncarvr
4,005
You started out talking about cases...your last post referred to cranks.
Words mean things..and by your words I have NO idea what you mean.
IF you plan on aligning your crank having NO experience, NO training, NO support...AND you are successful..
...I'd say you're pretty much a mechanical genious type.
Good luck!
chris_psmith
18
In re-assembling the cases you risk changing the alignment of the crank (if i believe the manual) hence the question on needing the special tool to assemble the case without changing the crank alignment, clear enough?
tony91
493
Good luck!
Dang! Easy killer.... :moon:
