Crank install
I got my new wiesco crank for my 02 yz250 installed by the freezer method last night and got the cases back together. All is good with the transmission and all but the crank halves are off center in the case. I have .043 clearance on one side and .021 on the other. I am measuring in between the case and crank right at the lube hole for the mains. Is this a bad thing? Does the crank need to be in the center? With the stock crank it measured .025 on each side. How do I center it if need be?? Any information would be helpful. Thanks
NO HAND
Subscriber
It will position itself when you are finished installing the crank gear on the clutch side. The fastener for this gear will correct the clearance on the right side and place the crank where it was intended to be.
