tsnobaddays
39
RC Valve Question
I am rebuilding a 2006 cr250 for the first time the crank rod has play in it up and down so its shot.
I wanted to know what the favored brand for a replacement is I was leaning towards the hot rod crank with wiseco piston complete kit. Any advise would be great thanks.
RC VALVE QUESTION: I cant get the rc valve off the cylinder I have tried using a rubber hammer but it wont move. I'm not having problems I was just going to clean it up while I had the bike apart. Any suggestions on how to remove the housing from the cylinder?
sharky243
246
Personally, I would go with a hotrods crank, and an OEM piston kit. I have experienced issues with the wiseco cranks failing early, and the wiseco pistons not fitting properly (too much clearance). Just my 2 cents from engine building experience, the choice is totally up to you !!!
