86' kdx 200
I was wondering what the chances are that my plug fouling is related to a bad crank seal. Is there a high chance I am sucking tranny fluid? That one run down the hwy at WOT seemed a little on the WHITE smoke side vs BLUE.
I moved the needle from the 3-up to the 5-up position, removed airbox cover, went one plug hotter and rode it a good 10 mins. Plug appears black but maybe I needed to run it longer. Also, I am not sure what kind of affect the clip movement would eventually have but I did expect the plug to make a difference being around 200 degrees warmer. How hot can I go, I made the move from 9 to 8, what about 7? The main jet is a 280 (orig 300) and the needle is stock. I think the jetting is fine, just a nice near-transparent blue puff out the back.
Thanks in advance
86' kdx 200
Thanks in advance
86' kdx 200
