I have been running the honda HP4 in both my engine and transmission since i purchased my crf450 in 03. My local source has dried up and my local parts guy is suggesting that i run Spectro Golden 4 Offroad 10w40 in the engine and Spectro Golden Gear Lube SAE80 in the transmission. The engine oil suggestion appears to match the specs of the HP4. While, the crf shop manual suggests 10w40 in the transmission, yet the SAE80 packaging states "recommended for wet-clutch transmission cases where an SAE 10w30, 10w40 or an SAE80w gear oil is recommended." So what's up? is it actually better to run the 80 weight oil in the transmission as my local guy says? Price does not matter as they are the same -- just want to use what will make the bike last the longest with least amount of work on my part...
