ironram
27
i have a delta vforce reed valve on my 99 yz 125 when i do the topend i want to replace it will i notice a diff with the vforce 3 is there any gain stepping up to this or will i be waisting my money thanks
oldfrt613
Feeble Sponsoring Member
443
The primary difference between the two valves is that all the reeds on the new valve are the same size and "snap" in ( no screw retention ). Old valve has different size petals on the inner and outer part of the cage and are screwed on. It is my understanding there is no performance advantage.
steve125
1,252
Actually the V-3 is a major improvement over the V-2. The internal reed cage design has really become engine specific, unlike the V-2's.
In dyno testing on a YZ 125 with the V-2, we lost 1/2 to 1 HP over the stock reed cage right up the dyno curve.
The V-3 on the other hand, matched the std reed valve up to peak. Then added 1/2 HP and over rev. Thats a major improvement over the V-2.
So my advise is to get the V-3 or go back to the stock reed cage. For sure don't run with the V-2 anymore.
