Did I change fork oil correctly?
bultaco4ever
149
Got a '97 KDX 220. I changed fork oil today for the first time. I took the forks out of the triple clamps, removed the fork tube cap, unscrewed the cap from the spring rod, pulled the spacer and spring out and dumped the oil.
I pushed the spring rod all the way down and up a few times to make sure all oil drained out.
Then I added new oil. The spring rod stayed in during the add process. I measured down 85mm and sucked out the excess oil. Then I buttoned it all back up.
The spring rod didn't have to be removed...did it?
julien_d
1,788
Need to pump the damping rod a few times after you fill it to make sure you bleed the air out. The level can drop considerably as the air bleeds out.
Joburble said:
You didn't mention that the fork was compressed when you added and measured the oil, but I assume it was, yes?
That would be less than interesting to ride? I was REALLY liking pulling the springs out, compressing the forks and checking it, if there are ANY doubts!
