rosehill_rider
- Mar 24, 2009
- 9
- 0
I split my case and put a new crankshaft in and then put it back together. When i put the sprocket back on the motor i noticed the whole set of gears and stuff move about 2 mm from side to side. (if you look at the motor from the front the movement is from left to right) I also found a homeless washer/spacer :bang: Should there be a movement like this or should ite stationary? thanks for any help
