After reading most of the suggestions here, I decided to set up my V-Force 2 reed cage with the low tension setting. Only problem was that the directions were different then the actual piece was. The diagram said to loosen the three reed stop nuts and slide the piece forward. What I did was take out the two bolts on the reed stop, turn it upside down so that the LOW side faced up. It seemed like it was right, the reeds definetely flapped easier. The bike picked up a good bit of bottom end too it seems, much better for cornering I hope. But I just wanted to verify that everything was right.
