Does anyone know anything about a motor on a 1983 RM125
Cobra_125
4
hi i just bought a 1983 suzuki 125 and i know nothing about the motor but want to learn about it and how to work on it so i can fix it and keep it clean and because i will be hopfully racing with it soon so i need to knwo about motor can anyone help
bikepilot
804
Its a 125cc two stroke:) does that help?
I would recomend that you get a factory service manual at at least pull the top end down, mic the piston and cylinder bore to ensure that they are in-spec. Check out the reeds, clean the carb and air filter and go for a ride. Of course if you come accross anything thats out of spec get it fixed up. You'll probably be ok on the piston and cylinder but might as well have a gasket set and a pair of rings handy. Be sure to use quality pre-mix and change the trans oil and antifreeze (if its water cooled) fairly often.
good luck
FRESH VIDEO
