ysr89
108
Hey, I was draining my crankcase oil, and as soon as I removed the bolt, my cam stopper and spring just fell out. They are numbers 19 and 21 on this diagram:
http://www.suzukipowersports.com/fiche_section_detail.asp
My question is do I have to split the cases to fix this, or can I just put them in through the drain bolt hole and put the bolt on to hold them? This is my only 4 stroke dirtbike, the complications have always turned me off to 4 strokes. I guess it's ironic that I have a cam problem, because being a 2 stroke fan, I don't believe dirtbikes should even have cams :|
