Someone recently mentioned that they close the fuel valve and run the bike until the carb runs dry after they ride. Can't remember who but thanks, I like the idea and started doing it for 2 reasons; I would rather not have fuel sitting in the carb for days at a time or more, and it makes pre-ride jetting easier by eliminating the chore of having to catch fuel when I open the carb. (whatever I miss washes the chain and sprocket)
Today I noticed small particles settled in the bottom of the float bowl drain plug, also one or two small water droplets. If I didn't drain the carb, this stuff would usually just come gushing out and I would miss it.
When I finished up and turned the fuel valve on, gas started to leak out of the overflow hose. This never happened before. It stopped once I kicked the engine over a few times. I guess the float valve stuck open from the last time I shut the bike down.
What is your opinion/experience on running the carb dry? I believe it overflowed because I ran it dry.
What about pros and cons? I know the lean surge when the carb runs dry isn't good, but how bad is it? I take care to only rev it enough to run all the gas out.
Would running it dry tend to suck any floating particles out of the carb & into the cylinder? I think that's where they end up anyway.
I am going to figure out why there is dirt in there.
Thanks--Joe Chief
Thanks--Joe Chief
