Rickster
12
On my kx125 I can move my clutch basket in and out about 1/8". I can`t feel any up or down
movement at all. I have the basket off and the play is still there in the driveshaft that the clutch
basket is attached to. I have the manual and it doesn`t say anything about radial movement. Is
this a normal condition,or should I investigate further?
cnl83
55
Dont know about the clutch, but I just rebuilt my bike (rod and all) and the rod moved side to side a bit.
im no pro..but it works!
motometal
2,680
as you are facing the clutch, radial movement would be the up and down, pushing it in and out would be axial movement, if I remember correctly.
for extra points, twisting it should be tangential movement (such as the backlash in the primary gear set).
