Ok, I see that this thread has surfaced from the depths of DRN so where do we stand.
Okie / Thump.. Any luck with contacts in your area regarding the construction of flags. I will be more than happy to call the company that I talked to before to get any info that we need in order to proceed.
Brian,
IrishEKU, over in the Kentuckiana forum, has found a guy that will do banners. You may want to check out his thread.
desert_racer,
See if your man can do gommeted banners as well. Irish is going to get a quote from a guy on 3'x5's with or without grommets. Also, make sure the guy understands that there will be several different screens desired. I'm bettin the sum of flags and banners for individual chapters won't be that great, but the total would be a good order.
Hey Guy's,
This is what I have come up with so far........http://www.dirtrider.net/forums3/showthread.php?threadid=50508
I have contacted THUMP with the info and am curious wheather or not to start an order. As I said in the thread, it may be a banner but it's a start!
Phillip.....AKA.......IRISHEKU
