Lack of Topend power after rebuild and reeds.
I rebuilt the topend on my 2001 220, I also installed a set of Boyesen dual stage reeds. I have heat cycled the engine three times. I heated it up once more, then took it up a constant fire road climb for 20 min to finish break in. I just took it out around the block a couple of times, and I have found that the high RPM area seems to be lacking. Not sure if I need to change the jetting, with the addition of the Boyesen reeds? I am in stock setup as far as jetting goes right now. Let me know if this is normal..........
