Never? Someone had better alert all the performance tuned to stroke owners and let them know.kawrider241 said:you will never find a performance tuned bike that idles(2-stroke)
And if you have your idle set so low it wont idle when you do that, then you will find yourself having to bumpstart it if you didn't keep the revs up manually, so what's the point? And that's not fun to do on "slippery terrain" downhills.kawrider241 said:And when descending long downhills definitely pull in the clutch and use your brakes as far as engine braking it is a small effect but is noticeable and useful for short periods.
It can hurt your engine in extreme suitations. Just search these forums for the "my engine seized when slowing down" posts.csdwarf said:That sounds like a good idea, have ur idle low so u can let off and it will help slow you down like your engine isnt running.
this doesnt hurt the engine does it? thanks
