MotoManiac
33
I have a 00 YZ125 just replaced my top end. Bike was running great all day, and then it happened. I had no top end left all of a sudden and my tranny felt funny. Took a lot of gas and clutch to move in first gear? When I got home I pulled my power valve arm cover off (I think that is what you call it). I found that my power valve arm broke. I felt this was only part of the problem, so I pulled the right case off of my engine. Inside the YPS governer lost it's pin and was loose. When I pulled the cover off the ball bearing and governer fell apart. Now at this point my arm is broke and my governer is apart. My main concern is that my bike is not shifting into nuetral. Can this be caused by the two broken componants or do you think other damaged occured. Before I split my cases I'm in desparate need of your advice. Thanks in advance Ryan
