EXC Lighting coil outpu wattage
enmerdeur
79
The KTM Specs show that the MXC has a lighting coild output wattage of 110 watts. The EXC spec lists no wattage number. Are they the same?
RoadRunner
110
The output varies by model I think. Which EXC or MXC are you looking at? One way to tell is if it has a 2K-2 ignition it's 40watt, 2K-3 is the 110 watt. It's kinda tricky to tell though, as the Euro models often come with a different ignition than the US models, and the specs are sometimes misquoted. If you are looking at fourstrokes, then I have no idea :P
