ws6transam said:Air pressure is critical only if you are racing: 20 PSI is probably plenty for both front and rear.
You never tried wfo and hanging your "sack" on the rear fender, and keep the front light? Sand corners are fun! Other than trying to eat the top of the triple clamp, you can fall a lot and not get hurt. And the wet sand set up is the opposite of dry.99raptor said:You have to get your sack up on the gascap if you wanna really turn it.
I was thinking the same thing. Maybe he meant 20 total as in 10 in the front and 10 in the rear....lolChili said:Plenty is an understatement, I don't think I've ever had 20 psi in a dirt bike tire other than when seating a bead after changing tires.
Normal riding we run 14 in the rear and 13 in the front, on a sand track we race at we will drop the rear to 10 or 11.
