Flyingbob, you indicated that the shcok chamber may be an issue if I attemp to swap TE570 suspension to a WR360. I measure the chanber and it's about 118mm (just the gold part). I contacted a guy who's selling a 2001 WR360 and he said his shock chamber measures approx. 115mm. That's close, maybe I'd just have to force the pip down or put a slight dent in it. Any thoughts.
Also, what are thoughts on the 2-strokes vrs. 4-strokes. My TE570 is a very easy bike to ride. It doesn't beat you to death and I can ride it much longer than my older 2-stroke KTM's. It is big though and can be a handful. It's a good 59-60" long and approx 258lbs. It seems like the 2-strokes are easire to toss around on the tight trails, etc. I'd assume the 360 with 14x50 gearing could run in the 60-70's. I need 70 plus for long desert races.
Bottom line, if I get the WR360 I'll have to choose between the 4-stroke and the 2-stroke in the end. I can't afford to keep both. Good thing is that both would be OHV year round (greensticker) out here in CA.
Thanks for any input.
