Flywheel movement = bearing play?
steve.emma
285
Hi all, question regarding main bearing play on a 2stroke. Bike in question is a 99' kx250 and i was checking for play in the main bearings by wiggling the flywheel etc.. up/down there is the very smallest amount of play and i suspect this would be gone if engine was hot. front to back or side to side there is no play, but if i pull/push flywheel in and out there is a bit of play at and you can hear it make a noise when i do this.
Is this normal? how much in/out play should there be? haven not noticed any vibration or noise when riding bike.
Any help appreciated.
steve.emma
285
in/out is not what you are concerned with. It's up/down and front/back.
Well im kinda worried about play full stop. but if you think that some in/out play is normal then cheers as thats what i thought also.
Why are you fooling around with the flywheel is a better question?
I dont really think checking for play in the main bearings is 'fooling around' as you put it. but if you are wondering what i was doing there i was in the process of installing a flywheel weight at the time.
RM_guy
Moderator
7,046
208
North East USA
I was fooling around with the back tire the other day and I thought it might have been flat but I was just folling around so I didn't do anything about it. :bang:
Usually if there is an issue, you check the end play? It was not mentioned? Now it makes sense Steve, thanks. About the side to side though, there should be a tolerance on how far it slides in and out, this does keep your rod centered in the bore. I have a 99 book to reference, and like I thought, there is no number for how much you can actually pull the crank in and out of the engine. Usually the collar on the drive gear, at the other end, when torqued properly, keeps it centered and tight. If yours moves enough to see, I would be concerned. The spec on adjusting it to center is not mentioned also, I take that as no play is good. Are there signs of seepage around the left crank seal? Putting on a fly wheel weight usually means you are after more bottom end? When a motor wears out of spec, the bottom end power goes first. I do not believe it is a flat tire.
1998RM250
426
My 2002 CR 250 I just picked up has a tiny bit of play side to side in the flywheel too and has me worried because I'm not sure whats acceptable!
2-Strokes 4-ever
1,842
4
Missouri
RM250 w/ all new lower end...
Slight in-out play, no front/back - up/down movement at all.
The lower end is new because... I noticed some play in the up/down - front/back directions, thought I could still get our big yearly 200 mile ride out of it... well, a main bearing cage came apart. New mains and seals, rebuilt crank, new rod, and had to replace a new top-end and replate a "perfectly good" cylinder... ($$$)
