The extra weight on the flywheel gives the engine more momentum, if you will. It makes it much more difficult to stall the engine at low revs, since the weight of the flywheel continues to turn the engine over. It also tames the "hit" of a 2t engine a bit, smoothing out the overall power delivery.
