Could somone please help me understand how to set the preload on my forks :( I got new springs from Race Tech and the instructions say=
Once set length is recorded(measured from washer at cap to where spring sits inside w/rod fully extended)measure length of spring and subtract. This would equal the size spacer for 0 preload then add amount of preload needed including washers for each end to make spacers.
OK , set length is= 466mm
The springs themselves are =472
So...466-472= -6
I want to have 10mm preload , so do I need 16mm combined spacers and washers to accomplish this??? :think:
I know I'm brain dead, please help the needy :confused:
I'm soooooo confused because right now there is one spring at 465 w/a 6mm spacer and the other at 475 w/no spacer, WTF?
So...466-472= -6
