Ok, I've read the threads and posts about removing some of the shims to help the fork action out, but I have a question. I pulled my forks apart and found two sets of valves. One is what I will call the base valve, which is the outer adjustable valve that sits at the bottom base of the fork. The other is located on the rod assembly, directly above the base valve.
So, which one do you alter? They both are valves and have shim stacks. So which one controls what?
TIA
TIA
