I have an 01YZ426f, the fork seals continue to fail about every 3 rides. I have had my local dealer replace seals once and have done it several times myself. Only modification has been a slight increase in fork oil height. Have inspected tubes, found one small scratch, polished out with 1000 grit sandpaper. Have not replaced bushings or damper rods. Used OEM seals. Have also tried to bleed excess air with forks compressed. I am convinced my work rivals that of the dealership as my seal replacement lasts approximately as long as theirs.
Any technical information regarding inspection procedures, use of aftermarket parts ie, seals, bushings, etc. would be appreciated.
Thanks, Mike
Thanks, Mike
