Was just reading a Dirtbike Q & A article and it was stated that moving your forks up any more than 7mm in the triple clamp can cause odd handling problems. On my 98 YZ250 I have moved them up 15mm to make it turn a little tighter. Although I have not identified any, I'm wondering if there may be some handling irregularities which may be caused by this adjustment. Sag is set at 95mm...should this be adjusted to compensate?
