I have a customer that started loosing rebound clicks on his KYB shock. It got to where it had only 9 clicks from full soft to full hard reb. I figured that the inner rebound rod inside the shaft had been corrodided or bent or sticking somehow. Once inside it I found that the point (which is threaded into the rod) had come loose which was making the rod longer & longer. I red locktighted it & put it back together and is working fine. I wonder if this is isolated or will we see more of it?
doc
doc
