Question? I alresdy have both front and back suspension done by jeff fredett with the gold valves. is it still worth the money to have the mx-tech suspension mods done.
NO The Gold Valves were set up for your wt. type of riding you do, your speed,ie(nov int expert). Ride the bike and get used to it,then play with the comp and reb adjustments 1 or 2 clicks at a time till you get it where you want it. If you were correct on your wt. type of riding, and such, then you will have excellent susp.
